XK (X150) V8-4.2L SC (2007)Центральный модуль управления сервисное обслуживание и ремонт
Тема в разделе "XK", создана пользователем Gileev Anton, 19 июл 2018.
    Центральный модуль управления: сервисное обслуживание и ремонт
    Central Control Module: Service and Repair
    Information and Entertainment Module (86.53.48)
    Removal
    1. Disconnect the battery ground cable.
    2. Remove the instrument panel center reinforcement trim panel.
    3. Release the navigation system module bracket.
    4. Remove the information and entertainment module.
    -Remove the 4 Torx bolts.
    -Disconnect the 2 electrical connectors.
    -Remove the 4 Torx screws.
    -Release the assembly
    -Release from the 5 clips.
    1. Install the information and entertainment module.
    -Tighten the Torx bolts to 6 Nm (4 lb.ft).
    -Connect the electrical connectors.
    2. Install the navigation system module bracket.
    -Tighten the Torx screws.
    3. Install the instrument panel center reinforcement trim panel.
    -Align the pegs and secure with the clips.
    4. Connect the battery ground cable.
    5. Connect WDS to the vehicle and configure a new module
