XJ6 (двигатели 2.9, 3.2, 3.6, 4.0, VIN-номера от 500001 до 667828): ANTI LOCK BRAKING SYSTEM ELECTRICS-FROM (V)594576 XJ6 и XJ12 (VIN-номера от 667829 до 708757): ANTI LOCK BRAKING SYSTEM 0. (Unillustrated Parts) From VIN (594576) Connector bracket LHD DBC6649 Socket head screw sensor to bracket SS106121J 1. Control module anti lock brake system From VIN (594576) DBC5422 2. Reverse inhibit relay green From VIN (594576) DBC2483 3. Main relay rear seat pan white. From VIN (594576) DAC7151 4. Relay yellow From VIN (594576) DAC4506 5. Speed sensor LH front anti lock brake system From VIN (594576) DBC5371 RH front anti lock brake system From VIN (594576) DBC5370 6. Speed sensor LH rear anti lock brake system From VIN (594576) DBC6247 RH rear anti lock brake system From VIN (594576) DBC6246 XJ6 и XJ12 (VIN-номера от 667829 до 708757) - Канада/США: MOTOR AND PUMP 1. Motor and pump 3.2 Litre JLM11253 4.0 Litre JLM11253 6.0 Litre From VIN (673299) JLM11253 2. .Pressure and warning switch kit JLM1908 3. Insulator kit JLM1464 4. Accumulator kit JLM1907 5. O-ring and seal kit JLM1477 6. Low pressure hose kit low JLM1892 7. Mounting bracket CCC6129
