Добрый день,уважаемые форумчане,подскажите как правильно снять радиатор с XJ40 чтобы не повредить сам радиатор и трубки охлаждения
93MY radiator replacement Postby naki_k » Sun Apr 10, 2011 6:34 pm ok, seems the radiator on 93 cars is different to 94's (and every other year for that matter). i need part number CC5476. anyone have one going spare? rob? so mines leaking from a crack in the plastic side part, where the lower bush is. any idea if that's repairable. i assume not as it plastic? the other problem is, i cant work out how the unions come apart? i have undone one nut, but its still seems to be connected. i gave it a wiggle, but it wont separate. any ideas? with nut without the one on the 94 rad is smaller the spare that i have i thought would be ok, but seen as its a 94 version, its now no use to me. i have two of these in fact, complete with electric fan cowl. anyone need one? its even got that bottom panel that's usually rusted to nothing! this is the second spare one, currently in yorkshire Ничего сложного поэтому наверно никто и не отвечает.
