У меня на даймлере в сороковом кузове находился на задней стороне моторного щита, в салоне за бардачком. на 308м и на 100ке с передней стороны моторного щита справа от двигателя если сидим в машине и смотрим вперед. На противоположной стороне в такой же нише находится главный тормозной. А если гугл спросить "год выпуска+марка+модель+ECU location" то он выдаст кучу картинок.
Trunk 1 Motor/Solenoid, trunk lid locking 2 ECU, fuel injection 3 Sending unit, fuel level 4 Fuel pump 5 Motor, antenna 6 Relay, antenna 7 Bulb failure unit, rear lamp 8 Bulb failure unit, rear lamp 9 Bulb failure unit, brake lamps 10 Motor, power sunroof
Passenger cabin A Fusebox Panel, driver side B Fusebox panel, passenger side 1 Motor/solenoid, door lock 2 Motor, window winder 3 Door speaker 4 Cruise control, main switch 5 Bulb failure unit 6 Relay, heated rear window 7 Relay, ignition protection 8 Relay, direction indicator 9 Fusebox, main 10 Bulb failure unit 11 Device, low coolant warning 12 Protection switch, door locks 13 Delay unit, wiper motor 14 Fusebox, auxilary 15 Protection switch, power windows 16 Protection switch, power windows 17 Bulb failure unit 18 Vacuum delay unit 19 Relay. power windows 20 Switch, power mirrors 21 Motor, power seat height adjustment 22 Switch, power mirrors 23 Relay, power locking
Hidden line fuses on the Jaguar SIII Location Purpose Cable Colours Engine compartment, above battery Horn, power circuit brown Center console, under gearlever surrounding plate Front seat(s) height adjustment white/pink Center console, behind radio power antenna purple/white Center console, right side of heater box AC compressor clutch yellow/brown Center console, right side of heater box Cigar lighter purple Center console. left side of heater box AC amplifier black Trunk, underneath fuel injection ECU rear lamp, right side red/black ring Trunk, underneath fuel injection ECU rear lamp, left side red/yellow ring Trunk, underneath fuel injection ECU unused on my car, perhaps side markers ? red above aux. fusebox, under facia, right side power door locks brown/blue For those considering to fit a towing bar : Behind the left rear lamp (has to be taken out) is a multiple connector (seven pins) for the electrical connection. It is taped to prevent the ingress of dirt. If you have the original Jaguar harness for the towing bar, it plugs right in. Standard 'bullet' connectors can be used instead to make your own wiring harness.
Да, бак по спец заказу!левый бак сгнил, поэтому временно так.Заливало свечи,машина стреляла, бензин улетал в трубу. Нашли причину, вакуумный усилитель сдох. Походу давление воздуха не доходила до эку.
